GT550 PARTS
Posted: Tue Jan 12, 2021 12:46 pm
I have a bunch of GT550 & a few GS550 used OEM parts (as noted). I’d like to clear these out of my garage. Too many to put photos here, but if you contact me at cbwells170@juno.com I can send pix as needed. Not sure of the exact model years but they are salvaged from vintage bikes that were used to resurrect a ’76 GT550 project. That bike has since moved along to a new owner. Keep in mind, these parts are original salvaged parts & as such are not necessarily PRETTY or show case material, but they are fully functional. I hope someone out there can use them as some are likely getting rather rare & I’d hate to scrap ‘em. Located in Binghamton, NY (near I81 at PA state line). I can pack & ship as needed but you pay the shipping cost. I’ll take $200 for the whole batch but here’s the individual list with asking prices.
$10 AIR BOX: w/chromed side pcs & inner cone frames. I can also provide some filter material.
$40 CENTER CYLINDER & MATCHED PISTON: w/rings, wrist pins, (3) roller bearings. NOTE: This single cylinder & piston got me home
(about 20 miles) after the 2 outer pistons holed! Must be good stuff! Right?
$20 LO PADDED BACKREST & LUGGAGE RACK: “Ocelot” brand originally for a GT750. Modified for GT550. Light pitting of the chrome.
$20 TRANSMISSION GEARS: Good condition. Not sure which set but we can figure it out.
$30 INJECTION OIL PUMP: Good condition. No reason to suspect any problems with it.
$20 INJECTION OIL “SPIDER” LINES: Fair condition.
Not cracked or damaged, but I suspect the flow valves at the cylinder ends will need rework.
$10 KICK STARTER & SHAFT ASSY: Chrome is pitted some but will clean up.
$30 STARTER MOTOR & COVER: Motor has been disassembled, cleaned & lubed. Brushes are original.
Reassembled & tested. (Note I am a retired electro-mech. Tech & have worked motors for 40 yrs.)
$10 SHOCK ABSORBERS (1pr): Chrome w/minor pitting. Fully functional. Only replaced 'cause I got a good deal on a shiney new set!
$5 FRONT SPROCKET (14-TOOTH): Very good condition.
$5 BRAKE LEVER:
$5 SHIFT LEVER & LINKAGE:
$5 KICK STAND: Rusty but solid.
$5 BRAKE SHOES (1pr): Kind of thin on material but functional.
$5 GS LEFT SWITCH CLUSTER: w/wiring & connectors.
$5 GS FOOT PEG ASSY: RT. FR. w/rubber. Rusty but not bent! Will clean up well.
$10 GS THROTTLE ASSY: w/Wiring:
$20 GS??? HEADLIGHT ASSY: Chrome w/Trim ring & good bulb. Minor pitting.
$10 GS INSTRUMENT HOUSING: (no gauges)
$20 GS ALTERNATOR CORE WINDING:
$10 GS UPPER TRIPLE CLAMP/RISER: Very good condition, freshly painted black.
$20 GS REAR FOOT PEGS & BRACKTS: Left & Right, good condition.
FREE MISC. HARDWARE & PARTS LOT: i.e. bottom case bolts, head studs w/nuts & washers, some carb floats, reflectors, a couple turn-signal lenses, 1 exhaust header collar, etc…. Mostly junk, but could be useful if you need any of it.
$5 BRAKE LEVER:
