Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat May 30, 2020 11:56 pm
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Carb inlet rubbers
PostPosted: Mon Feb 17, 2020 4:56 am
Offline
Suzuki 2-Strokes: GT750 hybrids (x2) VJ23A RGV500 TS185 R250
WANTED - information on which inlet rubbers people use on a GT750 motor to lift non-stock carbs clear of the clutch casing.
Garry.
_________________
Garry
I'm addicted to brake fluid, but I can stop anytime.
Top
 Profile
 Post subject: Re: Carb inlet rubbers
PostPosted: Mon Feb 17, 2020 5:26 am
Offline
garry55 wrote:
WANTED - information on which inlet rubbers people use to lift non-stock carbs clear of the clutch casing.
Garry.
Hi Garry,
I had clearance issues when fitting Mikuni VM 34mm carbs. In my case the float bowl on the left carb fouled the case just where the upper left bolt goes on the sprocket cover. I resorted to relieving the case to use the Flange mountings I had. When I fitted 38mm VM's (larger carb body) relieving the case looked like it could get out of hand. Instead I used some CNC machined inlet's which had a 15 degree angle to them, I used Sleeve rubbers between the inlets and carb.
Cheers Geoff
Top
 Profile
PostPosted: Mon Feb 17, 2020 6:06 am
Offline
Thanks Geoff - great solution to the problem.
However, the GT750 does not have bolt-on inlet stubs - they are part of the barrel casting.
regards
Garry.
_________________
Garry
Top
 Profile
PostPosted: Mon Feb 17, 2020 6:42 am
Offline
Soz Garry,
I do get too T500 focused sometimes lol :lol: It slipped my mind that your project is 3 cylinder. As I only have a minimum acquaintance of the GT750 I'll have to leave it to others for ideas. However I do know two guys who run race GT750 engines, I'll ask them what they use.
Cheers Geoff
Top
 Profile
PostPosted: Mon Feb 17, 2020 9:00 am
Offline
No problem Geoff - I got what I deserved as I forgot to mention that I was asking about lifting the carbs on a GT750 !
Amended the original post now.
And thanks for asking the GT750 racing guys :up:
regards
Garry.
_________________
Garry
Top
 Profile
PostPosted: Thu Feb 20, 2020 3:15 am
Offline
Hi Garry,
I contacted Cor Geraets and he provided this info:
"I have special inlet rubbers zo that i can fit the 38 racecarbs Whitout reworking the intake of the cylinder Also the angle of the carbs is then whitin the maximum Mikuni angle" (Cor is Dutch so I thought I'd keep his spelling :) )
Cor was interested in seeing your project so I'll grab one of the photos you've posted and forward it to him. He wants to see your potential issues so he might help further. Of course the first question is where did Cor source his angled inlet rubbers, I'm sure we will find out :up:
Cheers Geoff
(update: Cor had these inlet rubbers specially commissioned and sells them for 150 Euros a set. They provide an angle of approximately 15 degrees )
Top
 Profile
PostPosted: Thu Feb 27, 2020 12:27 pm
Offline
thanks for that Geoff.
I have sourced a set of angled inlet rubbers from a big 4T Suzuki that will do the job just fine.
And thank Cor for also responding to my plight :up:
_________________
Garry
Top
 Profile
PostPosted: Thu Feb 27, 2020 12:46 pm
Offline
Nice one, Garry :up:
Cheers Geoff
Top
 Profile
Who is online
Users browsing this forum: No registered users and 15 guests
Jump to:
Suzuki2Strokes.com
