So I drained what little splash was left in the tank and of course there was more hiding in there than it seemed. In fact there was more or less half a gallon.
I drained it with the filler cap closed and sure as God made little green apples, the flow soon slowed to a trickle. crack the cap and flow resumes. We all know what that means. Clogged, blocked or non functional vent. Right?
The filler cap is a new, anodized billet, aircraft type cap with check valves to allow the tank to breathe. That all fine if the system has a fuel pump to pull gas out and create sufficient negative pressure to crack the valves, but a little gas in a gravity feed doesn't create sufficient pressure drop, so the valves stay closed.
A little micro surgery and we have air flow and probably fuel flow. Second test today if it doesn't rain.
Then maybe we can start to log some relevant data. I'll have to move the CHT probe because it cools off as soon as road speed increases. The RPM pick up has been rewired to try to get a more consistent signal, but the A:F numbers are looking marginally rich up to 1/4 throttle and progressively leaner as it goes to WOT. Time for larger needle jets to go with the 120 mains. I might have to add a set of EGT channels to confirm what the lambda numbers.
It's educational.
