Crazy vs Stupid
Posted: Fri Apr 15, 2011 7:18 am
Nice distinction between the two states of mind!.....
A truck driver was doing his usual delivery to IMH (Institute of Mental Health).
He discovered a flat tire when he was about to go home.
He jacked up the truck and took the flat tire down.
When he was about to fix the tire, he accidentally dropped all the Bolts into the drain.
As he could not fish the bolts out, he started to panic.
A mental patient happened to walk past and asked the driver what Happened.
Helpless, the driver told the patient the whole incident.
The patient laughed at him and said, "You can't even fix such a simple Problem, no wonder you are destined to be a truck driver."
"Here's what you can do, take one bolt each from the other 3 tires and Fix it to this tire. Then drive to the nearest workshop and replace The missing ones. Easy as that"
The driver was very impressed and asked, "You're so smart ...so why are You here in the Mental Institute?"
The Patient replied, "Hellooo, I’m here because I'm crazy, not STUPID!"
