Suzuki s32-2... T10?
johnakay
I likes them jubblies
Suzuki 2-Strokes: bike
Post by johnakay »
does any body know if the Suzuki s32-2 share the same body as the T10??
a customer has ask me if my rack will fit the T10.
judging by pictures they looked the same and some racks looks familiar.
advant63
Country: canada
Suzuki 2-Strokes: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
Re: Suzuki s32-2... T10?
Post by advant63 »
i believe the t10 has a wider frame than the s32-2. my t10 is at work and s32's at home so i can't check, but can measure both if you like.
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
H2RICK
Country: CANADA
Post by H2RICK »
Dennis is probably correct. We currently have an S32-2 at the salvage yard where I work and it's quite a small frame compared to what I remember of the T-10.....but Dennis will have the definitive answers.
BTW, the S32-2 we have is a complete bike but the motor is out of the frame and partially dismantled because it threw out 4 or 5 bars from the commutator due to the PO dumbness. It is for sale as a complete bike. If you are interested, PM me and we can go from there.
We picked up over 100 bikes from an estate sale and there are some quite unique bikes in the bunch. Some are runners but most are not.
Heck, there's even a Rabbit model L202 scooter circa 1958 or so that's mostly complete and is looking for a good home. :wink:
GT550A Mint & Original
MBD Sufferer
johnakay
Post by johnakay »
advant63 wrote:i believe the t10 has a wider frame than the s32-2. my t10 is at work and s32's at home so i can't check, but can measure both if you like.
yes if you will please. thanks
advant63
Country: canada
Post by advant63 »
john, here are the t10 dimensions.
shock bolt 17mm
203 mm outside of shock bolt eyes
with the frame level the rear holes are 225mm behind and 55mm below the shock eyes.
the rear holes are 10mm and spaced 128mm apart across the frame.
i will measure the s32-2 if i can remember tonight. i walk past two of them twice a day and still forget to look at them. :oops:
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
johnakay
Post by johnakay »
[quote="advant63"]john, here are the t10 dimensions.
shock bolt 17mm
sorry but.......
shock bolt 17mm? is that the size of the bolt if it is its a bloody big un!
I'm not sure what you mean by this with the frame level? the rear holes are 225mm behind (behind what?) .
this I can understand ......the rear holes are 10mm and spaced 128mm apart across the frame.and this 55mm below the shock eyes
what I need to know is the width to either shock mount(across),
and from shock mount to rear bolt hole
