on the look out for a 73 buffalo carb
- Novice racer
- Suzuki 2-Strokes: gt750
hey guys i need a 73 buffalo carb .
i have seen one on flea-bay but it is of a re5,
and i am not sure if it was the same for both that year.
when trying to identify the exact carb i have where or what do i measure.
all help is appreciated,
mark
mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
1985 RZ350N
The 73 buffalo takes the same carb as the 72, except (naturally) the 73 has a longer slide, hence a slightly taller top cap. It is a 32mm bore carb, as measured at the outlet end where it mounts to the cylinder block. They are independently marked as R, L, C, on the casting by the choke slide (enrichner). Which one is it you need? Is yours missing, or just too far gone.
I can probably help you out, if you can wait for it to come from the great, white north. Let me know. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
- Novice racer
CARB
Hey fred what a star ,i cant see the l,r,c .
where the choke plunger goes on the body is a raised design but it dosesnt look like any letter i know, its like 3 bars a reverse r and 2 bars.
the caps are the later model i think (shorter style)
i think.
how much do you want for one, include the postage to 77079 houston.
cheers mark.
i think.
cheers mark.
1985 RZ350N
1985 RZ350N
I'm only familiar with the two styles. Short cap and slide on the 72's, and the longer slide on the 73's. Each of the three in a set is slightly different, thats why they are marked left, right, center. I 'll check one of my spares tomorrow and verify. Do you need the whole carb, jetting and all? Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
- Novice racer
Carb
Thanks Fred I think the whole enchalarda is the best option that way if it is different in some way I can just instal the whole thing as a unit.
Thanks again mark
Thanks again mark
1985 RZ350N
1985 RZ350N
- Novice racer
Chilly up there eh
Dam Fred I just looked at the weather up there you must be made of sterner stuff than me. It's 83 today in sweaty Houston !
1985 RZ350N
1985 RZ350N
I went looking and couldnt find the info on the 3 carbs but i am pretty sure that we discovered there are 3 different style 72~73 carbs . If i remenmber right there is a short body flat cap , a tall body flat cap and another that has a tall cap with a short body but a long slide . I bet Gunner still has this info ?
Mark.
I have a few carbs, and they are all designated with a code on the front of the choke slide chamber like so: 310, above, and 12R, or 12M, or 12L, below. That's looking at the carb from the front ( cylinder side ). The L has the vacuum spigot for the fuel tap, and the idle speed screw on the left. The M has no spigot, and the idle speed screw also on the left. The R has the Idle speed screw on the right. With this info, you should be able to figure out which one you are missing. Then just PM me with your address, and I'll get one off to you ASAP. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
