Over on the Yam aircooled RD forum, a bloke with a GT500 has been having trouble with air bubbles in one of his oil lines (the line to the left hand-cylinder).
After looking at the check valves and seals, he pulled the oil pump to see if there was any crud blocking the pump outlet.
Everything checked out OK.
As a last resort, he lifted the head and cylinder. A previous owner had hand-made a base gasket that covered the oilway
You can never underestimate the stupidity of previous owners
At least he made it out of gasket material i bet,,, ive seen gaskets made where you could see it was roughly cut out and pieces were hanging free out the sides with advertising included,,,, in this instance i'm speaking about, it was 'corn flakes' base gaskets.
I wonder if the Rice Krispies ones give higher performance because they go snap crackle and pop.
Apparently it was OK -- the other 3 oil feeds were fine so I guess there must have been just enough oil coming up from the feed to the bottom end on that cylinder to preserve it.Suzukidave wrote:Did he say if he was able to save that cylinder ?
That says a lot about the quality of modern day two stroke oils. Oil forum, anyone? Cheers.Craig380 wrote:Apparently it was OK -- the other 3 oil feeds were fine so I guess there must have been just enough oil coming up from the feed to the bottom end on that cylinder to preserve it.Suzukidave wrote:Did he say if he was able to save that cylinder ?
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
