Antiseize
kawonda750
Country: canada
Suzuki 2-Strokes: 1965 Yam74 gt550, 75 GT750 M, 2019 Kaw Z900RS
Antiseize
Post by kawonda750 »
Since I have had to fight with every bolt and screw on the engine of my 1975 GT750 after it sat for 35 years, I am looking at using Permatex antiseize. It claims to resist temps up to 870C or 1600 F.
The question is do I use it for upper and lower case assembly bolts and head bolts? I had one 8 mm head bolt break off and one of the water pump cover bolts break leading to time well wasted getting them out. All other bolts and screws were stuck and needed banging with a drift and/ or heating to finally remove them.
Opinions are welcomed.
Thanks Dave
badgereng
Suzuki 2-Strokes: GT500A - 1976
Re: Antiseize
Post by badgereng »
The GT500 I’m in the process of stripping (Cycle parts and Engine) had pretty much every thread liberally coated in copper-slip.
Not a bruised knuckle so far and only the crankcases left to split.
Not saying it’s any better or worse than the Permatex but just passing on my experience of the copper-slip.
I’m sure the Permatex will be more than adequate.
